/reference/
HwB: Centronics to LapLink Adapter
GoTo CableCABLEGoTo Main
This adapter will allow you to use a normal printercable (Centronics) as a LapLink/InterLink cable.
36 PIN CENTRONICS FEMALE (To the Printer cable)
25 PIN D-SUB MALE (To the Computer)
36 PIN CENTRONICS FEMALE to the Printer cable.
25 PIN D-SUB MALE to the Computer.
Name 36-Cen 25-DSub Name
Data Bit 0 2 15 Error
Data Bit 1 3 13 Select
Data Bit 2 4 12 Paper Out
Data Bit 3 5 10 Acknowledge
Data Bit 4 6 11 Busy
Acknowledge 10 5 Data Bit 3
Busy 11 6 Data Bit 4
Paper Out 12 4 Data Bit 2
Select 13 3 Data Bit 1
Error 32 2 Data Bit 0
Reset 16 16 Reset
Select 17 17 Select
Signal Ground 19-30+33 18-25 Signal Ground
Contributor: Joakim Цgren, Показать Email Petr Krc
Source: ?
Please send any comments to Joakim Цgren.
