This cable will work with both 10Base-T and 100Base-TX and is used to connect a network interface card to a hub or network outlet. These cables are sometimes called "whips".
(To network interface card).
(To hub).
RJ45 MALE CONNECTOR to network interface card).
RJ45 MALE CONNECTOR to hub).
| Name | Pin | Cable Color | Pin | Name |
| TX+ | 1 | White/Orange | 1 | TX+ |
| TX- | 2 | Orange | 2 | TX- |
| RX+ | 3 | White/Green | 3 | RX+ |
| 4 | Blue | 4 | ||
| 5 | White/Blue | 5 | ||
| RX- | 6 | Green | 6 | RX- |
| 7 | White/Brown | 7 | ||
| 8 | Brown | 8 |
Just for your information, this is how the pairs are named:
| Pair | Pins | Common color |
| 1 | 4 & 5 | Blue |
| 2 | 1 & 2 | Orange |
| 3 | 3 & 6 | Green |
| 4 | 7 & 8 | Brown |
The + side of each pair is called the "tip" and the - side is called the "ring", a reference to old telephone connectors.
Contributor: Joakim Цgren , ">Oscar Fernandez Sierra, ">Jeffrey R. Broido Source: ? Please send any comments to Joakim Цgren.
