/reference/
HwB: Amiga Video Connector
GoTo ConnectorCONNECTORGoTo Main
Amiga Video
23 PIN D-SUB MALE (At the Amiga)
23 PIN D-SUB MALE at the Amiga.
Pin Name Dir Description
1 /XCLK <-- Extern Clock
2 /XCLKEN <-- Extern Clock Enable (47 Ohm)
3 RED --> Analog Red (75 Ohm)
4 GREEN --> Analog Green (75 Ohm)
5 BLUE --> Analog Blue (75 Ohm)
6 DI --> Digital Intensity (47 Ohm)
7 DR --> Digital Red (47 Ohm)
8 DG --> Digital Green (47 Ohm)
9 DB --> Digital Blue (47 Ohm)
10 /CSYNC --> Composite Sync (47 Ohm)
11 /HSYNC --> Horizontal Sync (47 Ohm)
12 /VSYNC --> Vertical Sync (47 Ohm)
13 GNDRTN --- Digital Ground (for /XCLKEN) Don't connect with pin 16-20.
14 /PIXELSW --> Genlock overlay (47 Ohm)
15 /C1 --> Clock out (47 Ohm)
16 GND --- Video Ground
17 GND --- Video Ground
18 GND --- Video Ground
19 GND --- Video Ground
20 GND --- Video Ground
21 -12V --> -12 Volts DC (10 mA max) (A500/A600/A1200)
  -5V --> -5 Volts DC (10 mA max) (A1000/A2000/A3000/A4000)
22 +12V --> +12 Volts DC (100 mA max)
23 +5V --> +5 Volts DC (100 mA max)
Note: Direction is Computer relative Monitor.
Contributor: Joakim Цgren
Source: Amiga 4000 User's Guide from Commodore
Please send any comments to Joakim Цgren.
