/reference/
HwB: CDTV Diagnostic Slot Connector
GoTo ConnectorCONNECTORGoTo Main
80 PIN ??? CONNECTOR (At the computer)
80 PIN ??? CONNECTOR at the computer.
Pin Name Description
1 GND Ground
2 GND Ground
3 VCC +5 VDC
4 VCC +5 VDC
5 /CFGOUT Configout AutoConfig signal (not connected)
6 /CFGIN Configin AutoConfig signal (grounded)
7 GND Ground
8 CCKQ 3.58 MHz CCKQ clock (C3)
9 CDAC 7.16 MHz CDAC clock (90° before system clock)
10 CCK 3.58 MHz CCK clock (C1)
11 /OVR Override (Disables /DTACK generation of Gary)
12 XRDY External Ready (Generates wait states while low).
13 /INT2 Level 2 Interrupt
14 n/c not connected
15 A5 Address Bus 5
16 /INT6 Level 6 Interrupt
17 A6 Address Bus 6
18 A4 Address Bus 4
19 GND Ground
20 A3 Address Bus 3
21 A2 Address Bus 2
22 A7 Address Bus 7
23 A1 Address Bus 1
24 A8 Address Bus 8
25 /FC0 Processor Function Code Status (bit 0)
26 A9 Address Bus 9
27 /FC1 Processor Function Code Status (bit 1)
28 A10 Address Bus 10
29 /FC2 Processor Function Code Status (bit 2)
30 A11 Address Bus 11
31 GND Ground
32 A12 Address Bus 12
33 A13 Address Bus 13
34 /IPL0 Interrupt Priority Level (bit 0)
35 A14 Address Bus 14
36 /IPL1 Interrupt Priority Level (bit 1)
37 A15 Address Bus 15
38 /IPL2 Interrupt Priority Level (bit 2)
39 A16 Address Bus 16
40 /BERR Bus Error
41 A17 Address Bus 17
42 /VPA Valid Peripheral Address (asserted by Gary)
43 GND Ground
44 E E Clock
45 /VMA Valid Memory Address (asserted by Gary)
46 A18 Address Bus 18
47 /RST Reset
48 A19 Address Bus 19
49 /HLT Halt
50 A20 Address Bus 20
51 A22 Address Bus 22
52 A21 Address Bus 21
53 A23 Address Bus 23
54 /BR Bus Request
55 GND Ground
56 /BGACK Bus Grant Acknowledge
57 D15 Data Bus 15
58 /BG Bus Grant
59 D14 Data Bus 14
60 /DTACK Data Transfer Acknowledge (normally asserted by Gary)
61 D13 Data Bus 13
62 R/W Read/Write (high=read, low=write)
63 D12 Data Bus 12
64 /LDS Lower Data Strobe
65 D11 Data Bus 11
66 /UDS Upper Data Strobe
67 GND Ground
68 /AS Address Strobe
69 D0 Data Bus 0
70 D10 Data Bus 10
71 D1 Data Bus 1
72 D9 Data Bus 9
73 D2 Data Bus 2
74 D8 Data Bus 8
75 D3 Data Bus 3
76 D7 Data Bus 7
77 D4 Data Bus 4
78 D6 Data Bus 6
79 GND Ground
80 D5 Data Bus 5
Note: Pin 7-80 is equivalent with the Amiga 500's pin 13-86 at the 86 pin Amiga 500 connector.
Contributor: Joakim Цgren
Source: Darren Ewaniuk's CDTV Technical Information
Please send any comments to Joakim Цgren.
