/reference/
HwB: Amiga External Diskdrive Connector
GoTo ConnectorCONNECTORGoTo Main
23 PIN D-SUB FEMALE (At the Amiga)
23 PIN D-SUB FEMALE at the Amiga.
Pin Name Dir Description
1 /RDY <-> Disk Ready
2 /DKRD <-- Disk Read Data
3 GND --- Ground
4 GND --- Ground
5 GND --- Ground
6 GND --- Ground
7 GND --- Ground
8 /MTRXD OC Disk Motor Control
9 /SEL2 OC Select Drive 2
10 /DRES OC Disk Reset
11 /CHNG <-> Disk Removed From Drive-Latched Low
12 +5V --> +5 Volts DC (250 mA max)
13 /SIDE --> Select Disk Side (0=Upper, 1=Lower)
14 /WPRO <-> Disk is Write Protected
15 /TKO <-> Drive Head position over Track 0
16 /DKWE OC Disk Write Enable
17 /DKWD OC Disk Write Data
18 /STEP OC Step the Head-Pulse, First low, then high
19 DIR OC Select Head Direction (0=Inner, 1=Outer)
20 /SEL3 OC Select Drive 3
21 /SEL1 OC Select Drive 1
22 /INDEX OC Disk Index Pulse
23 +12V --> +12 Volts DC (160 mA max, 540 mA surge
Note: Direction is Computer relative Diskdrive.
Contributor: Joakim Цgren
Source: Amiga 4000 User's Guide from Commodore
Please send any comments to Joakim Цgren.
