PCI=Peripheral Component Interconnect.
IndustrialPCI is a version of PCI adapted for industrial and/or
embedded applications.
The IPCI connector has three parts:
Optional 60 pin PCI 64 bit extension (Top)
Mandatory 120 pin PCI 32 bit (Middle)
Optional 60 pin Custom I/O (Bottom)
(At the backplane) (At the device (card))
UNKNOWN CONNECTOR at the backplane.
UNKNOWN CONNECTOR at the device (card).
System Slot (Middle)
Pin
Name
Description
Note
A1
+3,3V
+3.3 VDC
A2
AD2
Address 2
A3
AD6
Address 6
A4
GND
Ground
A5
AD10
Address 10
A6
AD13
Address 13
A7
GND
Ground
A8
SDONE
Snoop Done
A9
GND
Ground
A10
FRAME#
Indicate Address or Data phase
A11
AD18
Address 18
A12
GND
Ground
A13
+5V
+5 VDC
A14
AD24
Address 24
A15
AD27
Address 27
A16
GND
Ground
A17
REQ2
Request 2
A18
GND
Ground
A19
CLK1
33 or 66 MHz Clock
A20
CLK2
A21
GND
Ground
A22
CLK3
A23
CLK4
A24
+3,3V
+3.3 VDC
B1
REQ64#
Request 64 ???
B2
AD3
Address 3
B3
+5V
+5 VDC
B4
AD8
Address 8
B5
+3,3V
+3.3 VDC
B6
AD14
Address 14
B7
PAR
Parity
B8
+3,3V
+3.3 VDC
B9
STOP#
Stop
B10
C/BE2#
Command, Byte Enable 2
B11
V(I/O)
+3.3 or +5 VDC
B12
AD21
Address 21
B13
+3,3V
+3.3 VDC
B14
V(I/O)
+3.3 or +5 VDC
B15
AD28
Address 28
B16
AD31
Address 31
B17
+3,3V
+3.3 VDC
B18
GNT3
Grant 3
B19
RST#
Reset
B20
NMI#
Non Maskable Interrupt
B21
X6
Reserved (6)
B22
+5V
+5 VDC
B23
RSTIN#
B24
USB+
Universal Serial Bus (USB)(+)
C1
ACK64#
Acknowledge 64 ???
C2
GND
Ground
C3
AD7
Address 7
C4
AD9
Address 9
C5
AD11
Address 11
C6
GND
Ground
C7
SERR#
System Error
C8
PERR#
Parity Error
C9
DEVSEL#
Device Select
C10
GND
Ground
C11
AD19
Address 19
C12
AD22
Address 22
C13
GND
Ground
C14
AD25
Address 25
C15
GND
Ground
C16
X1
Reserved (1)
C17
GNT2
Grant 2
C18
REQ4
Request 4
C19
SLEEP#/SDAT
Sleep/Serial Data (I2C)
3
C20
X4
Reserved (4)
C21
INTD#
Interrupt D
C22
INTB#
Interrupt B
C23
+5V
+5 VDC
C24
USB-
Universal Serial Bus (USB)(-)
D1
AD0
Address 0
D2
AD4
Address 4
D3
C/BE0#
Command, Byte Enable 0
D4
+3,3V
+3.3 VDC
D5
AD12
Address 12
D6
AD15
Address 15
D7
V(I/O)
+3.3 or +5 VDC
D8
LOCK#
Resource Lock
D9
TRDY#
Test Logic Ready
D10
AD16
Address 16
D11
AD20
Address 20
D12
+5V
+5 VDC
D13
+5V
+5 VDC
D14
AD26
Address 26
D15
AD29
Address 29
D16
REQ1
Request 1
D17
REQ3
Request 3
D18
V(I/O)
+3.3 or +5 VDC
D19
X2
Reserved (2)
D20
X5
Reserved (5)
D21
+3,3V
+3.3 VDC
D22
INTA#
Interrupt A
D23
ICPEN#/SCLK
ICPEN/Serial Clock (I2C)
3
D24
OSC (PWDN)
E1
AD1
Address 1
E2
AD5
Address 5
E3
GND
Ground
E4
M66EN
Enable 66Mhz PCI-bus
E5
GND
Ground
E6
C/BE1#
Command, Byte Enable 1
E7
SBO#
Snoop Backoff
E8
+5V
+5 VDC
E9
IRDY#
Initiator Ready
E10
AD17
Address 17
E11
GND
Ground
E12
AD23
Address 23
E13
C/BE3#
Command, Byte Enable 3
E14
GND
Ground
E15
AD30
Address 30
E16
GNT1
Grant 1
E17
+5V
+5 VDC
E18
GNT4
Grant 4
E19
X3
Reserved (3)
E20
GND
Ground
E21
INTC#
Interrupt C
E22
-12V
-12 VDC
E23
+12V
+12 VDC
E24
VBATT
1 = Pullup resistor of 2,7 kOhm on the System Slot (CPU).
2 = Pullup resistor of 330 ohm on the System Slot (CPU).
3 = Pullup resistor of 4,7 KB ohm, if not supported by the System
Slot (CPU).
Module Bus Slot (Middle)
Pin
Name
Description
Note
A1
+3,3V
+3.3 VDC
A2
AD2
Address 2
A3
AD6
Address 6
A4
GND
Ground
A5
AD10
Address 10
A6
AD13
Address 13
A7
GND
Ground
A8
SDONE
Snoop Done
A9
GND
Ground
A10
FRAME#
A11
AD18
Address 18
A12
GND
Ground
A13
+5V
+5 VDC
A14
AD24
Address 24
A15
AD27
Address 27
A16
GND
Ground
A17
REQ2
Request 2
A18
CLKM
A19
CLK1
33 or 66 MHz Clock
A20
CLK2
A21
GND
Ground
A22
CLK3
A23
CLK4
A24
+3,3V
+3.3 VDC
B1
REQ64#
Request 64 ???
B2
AD3
Address 3
B3
+5V
+5 VDC
B4
AD8
Address 8
B5
+3,3V
+3.3 VDC
B6
AD14
Address 14
B7
PAR
Parity
B8
+3,3V
+3.3 VDC
B9
STOP#
Stop
B10
C/BE2#
B11
V(I/O)
+3.3 or +5 VDC
B12
AD21
Address 21
B13
+3,3V
+3.3 VDC
B14
V(I/O)
+3.3 or +5 VDC
B15
AD28
Address 28
B16
AD31
Address 31
B17
+3,3V
+3.3 VDC
B18
GNT3
Grant 3
B19
RST#
Reset
B20
NMI#
B21
X6
Reserved (6)
B22
+5V
+5 VDC
B23
RSTIN#
B24
USB+
C1
ACK64#
Acknowledge 64 ???
C2
GND
Ground
C3
AD7
Address 7
C4
AD9
Address 9
C5
AD11
Address 11
C6
GND
Ground
C7
SERR#
System Error
C8
PERR#
Parity Error
C9
DEVSEL#
Device Select
C10
GND
Ground
C11
AD19
Address 19
C12
AD22
Address 22
C13
GND
Ground
C14
AD25
Address 25
C15
GND
Ground
C16
X1
Reserved (1)
C17
GNT2
Grant 2
C18
REQ4
Request 4
C19
SLEEP#/SDAT
C20
X4
Reserved (4)
C21
INTD#
Interrupt D
C22
INTB#
Interrupt B
C23
+5V
+5 VDC
C24
USB-
D1
AD0
Address 0
D2
AD4
Address 4
D3
C/BE0#
D4
+3,3V
+3.3 VDC
D5
AD12
Address 12
D6
AD15
Address 15
D7
V(I/O)
+3.3 or +5 VDC
D8
LOCK#
Resource Lock
D9
TRDY#
Test Logic Ready
D10
AD16
Address 16
D11
AD20
Address 20
D12
+5V
+5 VDC
D13
+5V
+5 VDC
D14
AD26
Address 26
D15
AD29
Address 29
D16
REQ1
Request 1
D17
REQ3
Request 3
D18
V(I/O)
+3.3 or +5 VDC
D19
X2
Reserved (2)
D20
X5
Reserved (5)
D21
+3,3V
+3.3 VDC
D22
INTA#
Interrupt A
D23
ICPEN#/SCLK
3
D24
OSC (PWDN)
E1
AD1
Address 1
E2
AD5
Address 5
E3
GND
Ground
E4
M66EN
E5
GND
Ground
E6
C/BE1#
E7
SBO#
Snoop Backoff
E8
+5V
+5 VDC
E9
IRDY#
Initiator Ready
E10
AD17
Address 17
E11
GND
Ground
E12
AD23
Address 23
E13
C/BE3#
E14
GND
Ground
E15
AD30
Address 30
E16
GNT1
Grant 1
E17
+5V
+5 VDC
E18
GNT4
Grant 4
E19
X3
Reserved (3)
E20
GND
Ground
E21
INTC#
Interrupt C
E22
-12V
-12 VDC
E23
+12V
+12 VDC
E24
VBATT
Card Slot (Middle)
Pin
Name
Description
Note
A1
+3,3V
+3.3 VDC
A2
AD2
Address 2
A3
AD6
Address 6
A4
GND
Ground
A5
AD10
Address 10
A6
AD13
Address 13
A7
GND
Ground
A8
SDONE
Snoop Done
A9
GND
Ground
A10
FRAME#
A11
AD18
Address 18
A12
GND
Ground
A13
+5V
+5 VDC
A14
AD24
Address 24
A15
AD27
Address 27
A16
GND
Ground
A17
IDSEL0
IDSEL0
A18
GND
Ground
A19
CLK1
33 or 66 MHz Clock
A20
GND
Ground
A21
GND
Ground
A22
GND
Ground
A23
GND
Ground
A24
+3,3V
+3.3 VDC
B1
REQ64#
Request 64 ???
B2
AD3
Address 3
B3
+5V
+5 VDC
B4
AD8
Address 8
B5
+3,3V
+3.3 VDC
B6
AD14
Address 14
B7
PAR
Parity
B8
+3,3V
+3.3 VDC
B9
STOP#
Stop
B10
C/BE2#
B11
V(I/O)
+3.3 or +5 VDC
B12
AD21
Address 21
B13
+3,3V
+3.3 VDC
B14
V(I/O)
+3.3 or +5 VDC
B15
AD28
Address 28
B16
AD31
Address 31
B17
+3,3V
+3.3 VDC
B18
GND
Ground
B19
RST#
Reset
B20
NMI#
B21
X6
Reserved (6)
B22
+5V
+5 VDC
B23
RSTIN#
B24
USB+
C1
ACK64#
Acknowledge 64 ???
C2
GND
Ground
C3
AD7
Address 7
C4
AD9
Address 9
C5
AD11
Address 11
C6
GND
Ground
C7
SERR#
System Error
C8
PERR#
Parity Error
C9
DEVSEL#
Device Select
C10
GND
Ground
C11
AD19
Address 19
C12
AD22
Address 22
C13
GND
Ground
C14
AD25
Address 25
C15
GND
Ground
C16
X1
Reserved (1)
C17
IDSEL1
Initialization Device Select 1
C18
GND
Ground
C19
SLEEP#/SDAT
C20
X4
Reserved (4)
C21
INTD#
Interrupt D
C22
INTB#
Interrupt B
C23
+5V
+5 VDC
C24
USB-
D1
AD0
Address 0
D2
AD4
Address 4
D3
C/BE0#
D4
+3,3V
+3.3 VDC
D5
AD12
Address 12
D6
AD15
Address 15
D7
V(I/O)
+3.3 or +5 VDC
D8
LOCK#
Resource Lock
D9
TRDY#
Test Logic Ready
D10
AD16
Address 16
D11
AD20
Address 20
D12
+5V
+5 VDC
D13
+5V
+5 VDC
D14
AD26
Address 26
D15
AD29
Address 29
D16
REQ1
Request 1
D17
IDSEL2
Initialization Device Select 2
D18
V(I/O)
+3.3 or +5 VDC
D19
X2
Reserved (2)
D20
X5
Reserved (5)
D21
+3,3V
+3.3 VDC
D22
INTA#
Interrupt A
D23
ICPEN#/SCLK
3
D24
OSC (PWDN)
E1
AD1
Address 1
E2
AD5
Address 5
E3
GND
Ground
E4
M66EN
E5
GND
Ground
E6
C/BE1#
E7
SBO#
Snoop Backoff
E8
+5V
+5 VDC
E9
IRDY#
Initiator Ready
E10
AD17
Address 17
E11
GND
Ground
E12
AD23
Address 23
E13
C/BE3#
E14
GND
Ground
E15
AD30
Address 30
E16
GNT1
Grant 1
E17
+5V
+5 VDC
E18
GNT4
Grant 4
E19
X3
Reserved (3)
E20
GND
Ground
E21
INTC#
Interrupt C
E22
-12V
-12 VDC
E23
+12V
+12 VDC
E24
VBATT
64-bit PCI (Top)
Pin
Name
Description
Note
A1
GND
Ground
A2
X10
Reserved (10)
A3
AD35
Address 35
A4
AD38
Address 38
A5
AD42
Address 42
A6
V(I/O)
+3.3 or +5 VDC
A7
V(I/O)
+3.3 or +5 VDC
A8
AD52
Address 52
A9
AD56
Address 56
A10
AD60
Address 60
A11
AD63
Address 63
A12
GND
Ground
B1
X7
Reserved (7)
B2
GND
Ground
B3
AD36
Address 36
B4
AD39
Address 39
B5
AD43
Address 43
B6
AD46
Address 46
B7
AD49
Address 49
B8
AD53
Address 53
B9
AD57
Address 57
B10
AD61
Address 61
B11
GND
Ground
B12
C/BE6#
Command, Byte Enable 6
C1
X8
Reserved (8)
C2
AD32
Address 32
C3
GND
Ground
C4
AD40
Address 40
C5
AD44
Address 44
C6
GND
Ground
C7
GND
Ground
C8
AD54
Address 54
C9
AD58
Address 58
C10
GND
Ground
C11
PAR64
Parity 64 ???
C12
C/BE7#
Command, Byte Enable 7
D1
X9
Reserved (9)
D2
AD33
Address 33
D3
AD37
Address 37
D4
GND
Ground
D5
AD45
Address 45
D6
AD47
Address 47
D7
AD50
Address 50
D8
AD55
Address 55
D9
GND
Ground
D10
AD62
Address 62
D11
C/BE4#
Command, Byte Enable 4
D12
X11
Reserved (11)
E1
GND
Ground
E2
AD34
Address 34
E3
V(I/O)
+3.3 or +5 VDC
E4
AD41
Address 41
E5
GND
Ground
E6
AD48
Address 48
E7
AD51
Address 51
E8
GND
Ground
E9
AD59
Address 59
E10
V(I/O)
+3.3 or +5 VDC
E11
C/BE5#
Command, Byte Enable 5
E12
X12
Reserved (12)
2 = Pullup resistor of 2,7 kOhm (5V bus system) or 8,2 kOhm
(3,3V bus system) on the backplane.
ISA96/AT96 (Bottom)
Pin
Name
Description
Note
A1
RSTDRV
A2
IRQ9
Interrupt 9
A3
SD11
Data 11
A4
SD9
Data 9
A5
IOCHRDY
A6
IOW#
I/O Write
A7
SA15
Address 15
A8
CLK
Clock
A9
SA10
Address 10
A10
SA7
Address 7
A11
T/C
A12
SA2
Address 2
B1
SD15
Data 15
B2
SD13
Data 13
B3
SD3
Data 3
B4
SD1
Data 1
B5
SMEMW#
System Memory Write
B6
SA18
Address 18
B7
SA14
Address 14
B8
DACK6#
DMA Acknowledge 6
B9
SA9
Address 9
B10
IRQ3
Interrupt 3
B11
IOCS16#
I/O 16-bit chip select
B12
SA1
Address 1
C1
SD7
Data 7
C2
SD5
Data 5
C3
SD10
Data 10
C4
SD8
Data 8
C5
AEN
Address Enable
C6
IOR#
I/O Read
C7
SA13
Address 13
C8
SA11
Address 11
C9
IRQ5
Interrupt 5
C10
SA6
Address 6
C11
SA4
Address 4
C12
IRQ11
Interrupt 11
D1
SD14
Data 14
D2
SD12
Data 12
D3
SD2
Data 2
D4
SD0
Data 0
D5
SMEMR#
System Memory Read
D6
SA17
Address 17
D7
REF#
D8
IRQ7
Interrupt 7
D9
SA8
Address 8
D10
MCS16#
D11
BALE
D12
SA0
Address 0
E1
SD6
Data 6
E2
SD4
Data 4
E3
0WS
E4
SBHE#
E5
SA19
Address 19
E6
SA16
Address 16
E7
SA12
Address 12
E8
DRQ6
DMA Request 6
E9
IRQ4
Interrupt 4
E10
SA5
Address 5
E11
SA3
Address 3
E12
IRQ10
Interrupt 10
1 = Pullup resistor must be integrated into the System Slot
(CPU).
