/reference/
HwB: ECP Parallel Connector
GoTo ConnectorCONNECTORGoTo Main
ECP Parallel
ECP = Extended Capabilities Port
25 PIN D-SUB FEMALE (At the PC)
25 PIN D-SUB FEMALE at the PC.
Pin Name Dir Description
1 nStrobe --> Strobe
2 data0 <-> Address, Data or RLE Data Bit 0
3 data1 <-> Address, Data or RLE Data Bit 1
4 data2 <-> Address, Data or RLE Data Bit 2
5 data3 <-> Address, Data or RLE Data Bit 3
6 data4 <-> Address, Data or RLE Data Bit 4
7 data5 <-> Address, Data or RLE Data Bit 5
8 data6 <-> Address, Data or RLE Data Bit 6
9 data7 <-> Address, Data or RLE Data Bit 7
10 /nAck <-- Acknowledge
11 Busy <-- Busy
12 PError <-- Paper End
13 Select <-- Select
14 /nAutoFd --> Autofeed
15 /nFault <-- Error
16 /nInit --> Initialize
17 /nSelectIn --> Select In
18 GND --- Signal Ground
19 GND --- Signal Ground
20 GND --- Signal Ground
21 GND --- Signal Ground
22 GND --- Signal Ground
23 GND --- Signal Ground
24 GND --- Signal Ground
25 GND --- Signal Ground
Note: Direction is Computer relative Device.
Contributor: Joakim Цgren, Показать Email Marco Furter
Source: Microsoft MSDN Library: Extended Capabilities Port Specs
Info: Microsoft MSDN Library
Please send any comments to Joakim Цgren.
