/reference/
HwB: Parallel (Olivetti M10) Connector
GoTo ConnectorCONNECTORGoTo Main
Available on an old portable computer called Olivetti M10.
26 PIN IDC MALE (At the Computer)
26 PIN IDC MALE at the Computer.
Pin Name Dir Description
1 /STROBE --> Strobe
2 D0 --> Data Bit 0
3 D1 --> Data Bit 1
4 D2 --> Data Bit 2
5 D3 --> Data Bit 3
6 D4 --> Data Bit 4
7 D5 --> Data Bit 5
8 D6 --> Data Bit 6
9 D7 --> Data Bit 7
10 /ACK <-- Acknowledge
11 BUSY <-- Busy
12 PE <-- Paper End
13 SELIN <-- Select In
14 GND --- Signal Ground
15 GND --- Signal Ground
16 GND --- Signal Ground
17 GND --- Signal Ground
18 GND --- Signal Ground
19 GND --- Signal Ground
20 GND --- Signal Ground
21 GND --- Signal Ground
22 GND --- Signal Ground
23 GND --- Signal Ground
24 GND --- Signal Ground
25 RESETGND --- Reset Ground
26 /RESET <-- Reset
Note: Direction is Computer relative Device.
Contributor: Joakim Цgren, Показать Email Filippo Fiani
Source: ?
Please send any comments to Joakim Цgren.
