/reference/
HwB: SCART Connector
GoTo ConnectorCONNECTORGoTo Main
SCART
21 PIN SCART FEMALE (At the video/TV)
21 PIN SCART MALE (At the cable)
21 PIN SCART FEMALE at the Video/TV.
21 PIN SCART MALE at the Cable.
Pin Name Description Signal Level Impedance
1 AOR Audio Out Right 0.5 V rms <1k ohm
2 AIR Audio In Right 0.5 V rms >10k ohm
3 AOL Audio Out Left + Mono 0.5 V rms <1k ohm
4 AGND Audio Ground
5 B GND RGB Blue Ground
6 AIL Audio In Left + Mono 0.5 V rms >10k ohm
7 B RGB Blue In 0.7 V 75 ohm
8 SWTCH Audio/RGB switch / 16:9
9 G GND RGB Green Ground
10 CLKOUT Data 2: Clockpulse Out (Unavailable ??)
11 G RGB Green In 0.7 V 75 ohm
12 DATA Data 1: Data Out (Unavailable ??)
13 R GND RGB Red Ground
14 DATAGND Data Ground
15 R RGB Red In / Chrominance 0.7 V (Chrom.: 0.3 V burst) 75 ohm
16 BLNK Blanking Signal 1-3 V=RGB, 0-0.4 V=Composite 75 ohm
17 VGND Composite Video Ground
18 BLNKGND Blanking Signal Ground
19 VOUT Composite Video Out 1 V 75 ohm
20 VIN Composite Video In / Luminance 1 V 75 ohm
21 SHIELD Ground/Shield (Chassis)
Contributor: Joakim Цgren
Source: Various sources, Video Demystified at Keith Jack's pages
Please send any comments to Joakim Цgren.
