/reference/
HwB: SCSI-II External Hi D-Sub (Single-ended) Connector
GoTo ConnectorCONNECTORGoTo Main
50 PIN HI-DENSITY D-SUB FEMALE (At the controller & devices).
50 PIN HI-DENSITY D-SUB MALE (To the cable).
50 PIN HI-DENSITY D-SUB FEMALE at the controller & devices.
50 PIN HI-DENSITY D-SUB MALE at the cable.
Pin Name Dir Description
1-25 GND --- Ground
26 DB0 <-> Data Bus 0
27 DB1 <-> Data Bus 1
28 DB2 <-> Data Bus 2
29 DB3 <-> Data Bus 3
30 DB4 <-> Data Bus 4
31 DB5 <-> Data Bus 5
32 DB6 <-> Data Bus 6
33 DB7 <-> Data Bus 7
34 PARITY <-> Data Parity (odd Parity)
35 GND --- Ground
36 GND --- Ground
37 GND --- Ground
38 TMPWR <-> Termination Power
39 GND --- Ground
40 GND --- Ground
41 /ATN <-- Attention
42 n/c - Not connected
43 /BSY <-> Busy
44 /ACK <-- Acknowledge
45 /RST <-> Reset
46 /MSG --> Message
47 /SEL <-> Select
48 /C/D --> Control/Data
49 /REQ --> Request
50 /I/O --> Input/Output
Note: Direction is Device relative Bus (other Devices).
Contributor: Joakim Цgren
Source: ?
Please send any comments to Joakim Цgren.
