/reference/
HwB: SCSI External D-Sub (Future Domain) Connector
GoTo ConnectorCONNECTORGoTo Main
Seems to be available on some Future Domain SCSI-controllers only.
25 PIN D-SUB FEMALE (At the controller)
25 PIN D-SUB MALE (At the cable)
25 PIN D-SUB FEMALE at the controller.
25 PIN D-SUB MALE at the cable.
Pin Name Dir Description
1 GND --- Ground
2 DB1 <-> Data Bus 1
3 DB3 <-> Data Bus 3
4 DB5 <-> Data Bus 5
5 DB7 <-> Data Bus 7
6 GND --- Ground
7 /SEL <-> Select
8 GND --- Ground
9 TMPWR <-> Termination Power
10 /RST <-> Reset
11 C/D --> Control/Data
12 I/O --> Input/Output
13 GND --- Ground
14 DB0 <-> Data Bus 0
15 DB2 <-> Data Bus 2
16 DB4 <-> Data Bus 4
17 DB6 <-> Data Bus 6
18 PARITY <-> Data Parity
19 GND --- Ground
20 /ATN <-- Attention
21 /MSG --> Message
22 /ACK <-- Acknowledge
23 BSY <-> Busy
24 /REQ --> Request
25 GND --- Ground
Note: Direction is Device relative Bus (other Devices).
Contributor: Joakim Цgren
Source: TheRef TechTalk
Please send any comments to Joakim Цgren.
