SCSI=Small Computer System Interface.
Based on an original design by Shugart Associates. SCSI was
ratified in 1986.
(At the controller & harddisk)
(At the cable.)
50 PIN IDC MALE at the controller & harddisk.
50 PIN IDC FEMALE at the cable.
| Pin | Name | Dir | Description |
| 2 | DB0 | Data Bus 0 | |
| 4 | DB1 | Data Bus 1 | |
| 6 | DB2 | Data Bus 2 | |
| 8 | DB3 | Data Bus 3 | |
| 10 | DB4 | Data Bus 4 | |
| 12 | DB5 | Data Bus 5 | |
| 14 | DB6 | Data Bus 6 | |
| 16 | DB7 | Data Bus 7 | |
| 18 | PARITY | Data Parity (odd Parity) | |
| 20 | GND | Ground | |
| 22 | GND | Ground | |
| 24 | GND | Ground | |
| 26 | TMPWR | Termination Power | |
| 28 | GND | Ground | |
| 30 | GND | Ground | |
| 32 | /ATN | Attention | |
| 34 | GND | Ground | |
| 36 | /BSY | Busy | |
| 38 | /ACK | Acknowledge | |
| 40 | /RST | Reset | |
| 42 | /MSG | Message | |
| 44 | /SEL | Select | |
| 46 | /C/D | Control/Data | |
| 48 | /REQ | Request | |
| 50 | /I/O | Input/Output |
All odd-numbered pins, except pin 25, are connected to ground. Pin 25 is left open.
Contributor: Joakim Цgren Source: ? Please send any comments to Joakim Цgren.
