/reference/
HwB: Universal Serial Bus (USB) (Tech) Connector
GoTo ConnectorCONNECTORGoTo Main
Universal Serial Bus (USB) (Technical)
USB was developed by Compaq, Digital Equipment Corp, IBM PC Co., Intel, Microsoft, NEC and Northern Telecom.
Features:
Bandwidth:
Definitions:
USB Host = The computer, only one host per USB system.
USB Device = A hub or a Function.
Power usage:
Bus-powered hubs: Draw Max 100 mA at power up and 500 mA normally.
Self-powered hubs: Draw Max 100 mA, must supply 500 mA to each port.
Low power, bus-powered functions: Draw Max 100 mA.
High power, bus-powered functions: Self-powered hubs: Draw Max 100 mA, must supply 500 mA to each port.
Self-powered functions: Draw Max 100 mA.
Suspended device: Max 0.5 mA
Voltage:
Shielding:
Shield should only be connected to Ground at the host. No device should connect Shield to Ground.
Cable:
Shielded:
Data: 28 AWG twisted
Power: 28 AWG - 20 AWG non-twisted
Non-shielded:
Data: 28 AWG non-twisted
Power Gauge Max length
28 0.81 m
26 1.31 m
24 2.08 m
22 3.33 m
20 5.00 m
Cable colors:
Pin Name Cable color Description
1 VCC Red +5 VDC
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
Contributor: Joakim Цgren
Sources: USB FAQ at USB Implementers Forum
Sources: USB Specification v1.0 at
Please send any comments to Joakim Цgren.
