/reference/
HwB: VGA (15) Connector
GoTo ConnectorCONNECTORGoTo Main
VGA (15)
VGA=Video Graphics Adapter or Video Graphics Array.
Videotype: Analogue.
15 PIN HIGHDENSITY D-SUB FEMALE (At the videocard)
15 PIN HIGHDENSITY D-SUB MALE (At the monitor cable)
15 PIN HIGHDENSITY D-SUB FEMALE at the videocard.
15 PIN HIGHDENSITY D-SUB MALE at the monitor cable.
Pin Name Dir Description
1 RED --> Red Video (75 ohm, 0.7 V p-p)
2 GREEN --> Green Video (75 ohm, 0.7 V p-p)
3 BLUE --> Blue Video (75 ohm, 0.7 V p-p)
4 ID2 <-- Monitor ID Bit 2
5 GND --- Ground
6 RGND --- Red Ground
7 GGND --- Green Ground
8 BGND --- Blue Ground
9 KEY - Key (No pin)
10 SGND --- Sync Ground
11 ID0 <-- Monitor ID Bit 0
12 ID1 or SDA <-- Monitor ID Bit 1
13 HSYNC or CSYNC --> Horizontal Sync (or Composite Sync)
14 VSYNC --> Vertical Sync
15 ID3 or SCL <-- Monitor ID Bit 3
Note: Direction is Computer relative Monitor.
Contributor: Joakim Цgren
Source: ?
Please send any comments to Joakim Цgren.
