/reference/
HwB: VGA (VESA DDC) Connector
GoTo ConnectorCONNECTORGoTo Main
VGA (VESA DDC)
VGA=Video Graphics Adapter or Video Graphics Array.
VESA=Video Electronics Standards Association.
DDC=Display Data Channel.
Videotype: Analogue.
15 PIN HIGHDENSITY D-SUB FEMALE (At the videocard)
15 PIN HIGHDENSITY D-SUB MALE (At the monitor cable)
15 PIN HIGHDENSITY D-SUB FEMALE at the videocard.
15 PIN HIGHDENSITY D-SUB MALE at the monitor cable.
Pin Name Dir Description
1 RED --> Red Video (75 ohm, 0.7 V p-p)
2 GREEN --> Green Video (75 ohm, 0.7 V p-p)
3 BLUE --> Blue Video (75 ohm, 0.7 V p-p)
4 RES - Reserved
5 GND --- Ground
6 RGND --- Red Ground
7 GGND --- Green Ground
8 BGND --- Blue Ground
9 +5V --> +5 VDC
10 SGND --- Sync Ground
11 ID0 <-- Monitor ID Bit 0 (optional)
12 SDA <-> DDC Serial Data Line
13 HSYNC or CSYNC --> Horizontal Sync (or Composite Sync)
14 VSYNC --> Vertical Sync
15 SCL <-> DDC Data Clock Line
Note: Direction is Computer relative Monitor.
Contributor: Joakim Цgren
Source: ?
Please send any comments to Joakim Цgren.
