/reference/
HwB: VESA Feature Connector
GoTo ConnectorCONNECTORGoTo Main
VESA Feature
26 PIN IDC MALE (At the videocard)
26 PIN IDC at the Video card.
Pin Name Description
1 PD0 DAC Pixel Data Bit 0 (PB)
2 PD1 DAC Pixel Data Bit 1 (PG)
3 PD2 DAC Pixel Data Bit 2 (PR)
4 PD3 DAC Pixel Data Bit 3 (PI)
5 PD4 DAC Pixel Data Bit 4 (SB)
6 PD5 DAC Pixel Data Bit 5 (SG)
7 PD6 DAC Pixel Data Bit 6 (SR)
8 PD7 DAC Pixel Data Bit 7 (SI)
9 CLK DAC Clock
10 BLK DAC Blanking
11 HSYNC Horizontal Sync
12 VSYNC Vertical Sync
13 GND Ground
14 GND Ground
15 GND Ground
16 GND Ground
17   Select Internal Video
18   Select Internal Sync
19   Select Internal Dot Clock
20 n/c Not used
21 GND Ground
22 GND Ground
23 GND Ground
24 GND Ground
25 n/c Not used
26 n/c Not used
Contributor: Joakim Цgren
Source: ?
Please send any comments to Joakim Цgren.
