First at each page there a short heading describing what the connector is.
After that there is at each page there is one or more pictures of the connectors. Sometimes there is some question marks only. This means that I don't know what kind of connector it is or how it looks.
(At the computer)
There may be some pictures I haven't drawn yet. I illustrate this with the following advanced picture:
(At the computer)
Normally are one or more pictures. These are seen from the front, and NOT the soldside. Holes (female connectors usually) are darkened. Look at the example below. The first is a female connector and the send a male. The texts insde parentheses will tell you at which kind of the device it will look like that.
(At the videocard)
(At the monitor cable)
Below the pictures there is texts that describes the connectors. Including the name of the physical connector.
5 PIN DIN 180° (DIN41524) at the computer.
The pin table is perhaps the information you are looking for. Should be simple to read. Contains mostly the following three columns; Pin, Name & Description.
| Pin | Name | Description |
| 1 | CLOCK | Key Clock |
| 2 | GND | GND |
| 3 | DATA | Key Data |
| 4 | VCC | +5 VDC |
| 5 | n/c | Not connected |
All persons that helped me or sent me information about the connector will be listed here. The source of the information is perhaps a book or another site. I must admit that I am bad at writing the source, but I will try to fill in these in the future.
Contributor: Joakim Цgren Source: Amiga 4000 User's Guide from Commodore
