| Навигатор: QRZ.RU > Радиолюбительские справочники > Справочник компьютерного инженера |
ISA=Industry Standard Architecture
(at the card)
(at the computer)
62+36 PIN EDGE CONNECTOR MALE at the card.
62+36 PIN EDGE CONNECTOR FEMALE at the computer.
| Pin | Name | Dir | Description |
| A1 | /I/O CH CK | I/O channel check; active low=parity error | |
| A2 | D7 | Data bit 7 | |
| A3 | D6 | Data bit 6 | |
| A4 | D5 | Data bit 5 | |
| A5 | D4 | Data bit 4 | |
| A6 | D3 | Data bit 3 | |
| A7 | D2 | Data bit 2 | |
| A8 | D1 | Data bit 1 | |
| A9 | D0 | Data bit 0 | |
| A10 | I/O CH RDY | I/O Channel ready, pulled low to lengthen memory cycles | |
| A11 | AEN | Address enable; active high when DMA controls bus | |
| A12 | A19 | Address bit 19 | |
| A13 | A18 | Address bit 18 | |
| A14 | A17 | Address bit 17 | |
| A15 | A16 | Address bit 16 | |
| A16 | A15 | Address bit 15 | |
| A17 | A14 | Address bit 14 | |
| A18 | A13 | Address bit 13 | |
| A19 | A12 | Address bit 12 | |
| A20 | A11 | Address bit 11 | |
| A21 | A10 | Address bit 10 | |
| A22 | A9 | Address bit 9 | |
| A23 | A8 | Address bit 8 | |
| A24 | A7 | Address bit 7 | |
| A25 | A6 | Address bit 6 | |
| A26 | A5 | Address bit 5 | |
| A27 | A4 | Address bit 4 | |
| A28 | A3 | Address bit 3 | |
| A29 | A2 | Address bit 2 | |
| A30 | A1 | Address bit 1 | |
| A31 | A0 | Address bit 0 | |
| B1 | GND | Ground | |
| B2 | RESET | Active high to reset or initialize system logic | |
| B3 | +5V | +5 VDC | |
| B4 | IRQ2 | Interrupt Request 2 | |
| B5 | -5VDC | -5 VDC | |
| B6 | DRQ2 | DMA Request 2 | |
| B7 | -12VDC | -12 VDC | |
| B8 | /NOWS | No WaitState | |
| B9 | +12VDC | +12 VDC | |
| B10 | GND | Ground | |
| B11 | /SMEMW | System Memory Write | |
| B12 | /SMEMR | System Memory Read | |
| B13 | /IOW | I/O Write | |
| B14 | /IOR | I/O Read | |
| B15 | /DACK3 | DMA Acknowledge 3 | |
| B16 | DRQ3 | DMA Request 3 | |
| B17 | /DACK1 | DMA Acknowledge 1 | |
| B18 | DRQ1 | DMA Request 1 | |
| B19 | /REFRESH | Refresh | |
| B20 | CLOCK | System Clock (67 ns, 8-8.33 MHz, 50% duty cycle) | |
| B21 | IRQ7 | Interrupt Request 7 | |
| B22 | IRQ6 | Interrupt Request 6 | |
| B23 | IRQ5 | Interrupt Request 5 | |
| B24 | IRQ4 | Interrupt Request 4 | |
| B25 | IRQ3 | Interrupt Request 3 | |
| B26 | /DACK2 | DMA Acknowledge 2 | |
| B27 | T/C | Terminal count; pulses high when DMA term. count reached | |
| B28 | ALE | Address Latch Enable | |
| B29 | +5V | +5 VDC | |
| B30 | OSC | High-speed Clock (70 ns, 14.31818 MHz, 50% duty cycle) | |
| B31 | GND | Ground | |
| C1 | SBHE | System bus high enable (data available on SD8-15) | |
| C2 | LA23 | Address bit 23 | |
| C3 | LA22 | Address bit 22 | |
| C4 | LA21 | Address bit 21 | |
| C5 | LA20 | Address bit 20 | |
| C6 | LA18 | Address bit 19 | |
| C7 | LA17 | Address bit 18 | |
| C8 | LA16 | Address bit 17 | |
| C9 | /MEMR | Memory Read (Active on all memory read cycles) | |
| C10 | /MEMW | Memory Write (Active on all memory write cycles) | |
| C11 | SD08 | Data bit 8 | |
| C12 | SD09 | Data bit 9 | |
| C13 | SD10 | Data bit 10 | |
| C14 | SD11 | Data bit 11 | |
| C15 | SD12 | Data bit 12 | |
| C16 | SD13 | Data bit 13 | |
| C17 | SD14 | Data bit 14 | |
| C18 | SD15 | Data bit 15 | |
| D1 | /MEMCS16 | Memory 16-bit chip select (1 wait, 16-bit memory cycle) | |
| D2 | /IOCS16 | I/O 16-bit chip select (1 wait, 16-bit I/O cycle) | |
| D3 | IRQ10 | Interrupt Request 10 | |
| D4 | IRQ11 | Interrupt Request 11 | |
| D5 | IRQ12 | Interrupt Request 12 | |
| D6 | IRQ15 | Interrupt Request 15 | |
| D7 | IRQ14 | Interrupt Request 14 | |
| D8 | /DACK0 | DMA Acknowledge 0 | |
| D9 | DRQ0 | DMA Request 0 | |
| D10 | /DACK5 | DMA Acknowledge 5 | |
| D11 | DRQ5 | DMA Request 5 | |
| D12 | /DACK6 | DMA Acknowledge 6 | |
| D13 | DRQ6 | DMA Request 6 | |
| D14 | /DACK7 | DMA Acknowledge 7 | |
| D15 | DRQ7 | DMA Request 7 | |
| D16 | +5 V | ||
| D17 | /MASTER | Used with DRQ to gain control of system | |
| D18 | GND | Ground |
Note: Direction is Motherboard relative ISA-Cards.
Note: B8 was /CARD SLCDTD on the XT. Card selected, activated by cards in XT's slot J8
| Contributor: | Joakim Цgren, Rob Gill |
| Source: | IBM PC/AT Technical Reference, pages 1-25 through 1-37 |
| comp.sys.ibm.pc.hardware.* FAQ Part 4 - maintained by Ralph Valentino |
Информация предоставлена справочником The Hardware Book Team 1996-2004.
